Higher mileage cars
Higher mileage cars
Just wondering...my cobra has 135K on her. She runs great and i would like to keep it that way. What type of oil should i use at this mileage level. I am thinking of switching to synthetic. Also, with gas prices soaring would there be any harm in running the 87 octane? I've always used 91 (California) but every little bit helps these days. Thanks.
'98 White terminated Cobra
'93 Black Cobra #4831
What kind of oil have you been using and how often did you change it?
Is your engine using any oil now?
I have always used synthetic oil and have had cars go over 150k with no oil related issues. I change oil & filters every 5k miles
You could start using Synthetic but you could start seeing leaks develop typically around valve covers, oil pan gasket, and rear main seal (sort of common with 5.0 Fords)
As for gas these engines have 9 to 1 compression so I use 89 here with no problems. I have used our 93 but don;t see any real difference.
K98Dave
88 LX hatch -(SOLD
1984 SVO number 110 (SOLD)
93 Cobra Blk# 2100 Still a Virgin- No Mods
95 Lightning (SOLD)
86 LX Restoration in work)
2013 F150 Reg cab Short Bed 5.0
88 LX hatch -(SOLD
95 Lightning (SOLD)
ive never used anything but 87 octane , for everyday driving its fine, now if you were gonna be racing it , i would use aa higher octane . and i use synthetic in everything from my lawnmower to my to my truck with 170k on it no problems and usually go around 7k between changes. When i first started using it , i had a 90 chevy truck , i switched from conventional and noticed about 1.5 mpg increase using 5w30 in it.
I've got my popcorn ready for this one. My car has somewhere between 130-150K on the ticker...previous owner swapped a gauge cluster so the CarFax is a real cluster!
I've changed the oil twice...once when I got it and once over the weekend. I put about 2000 miles on it between changes (and a lot of sitting) and it looks like it consumed about 1.25 quarts. Nothing on the driveway but I do see some minor residue in places under the car, including the pan.
I went ahead and used some high mileage dino to start and will eventually switch to Mobil 1 like my other vehicles.
Anyway, I'll be watching this one!
Tom
Tom
Hmm, would be nice to use 87 and save a few bucks. I've always used 93. How many others are using 87?1993cobra wrote:ive never used anything but 87 octane , for everyday driving its fine, now if you were gonna be racing it , i would use aa higher octane . and i use synthetic in everything from my lawnmower to my to my truck with 170k on it no problems and usually go around 7k between changes. When i first started using it , i had a 90 chevy truck , i switched from conventional and noticed about 1.5 mpg increase using 5w30 in it.
I also run mobil 1 synthetic..
- RollTide93
- aaronlstiles
I agree with you Aaron. I would be affraid to use 87 everyday. Might be a little more expensive but gives me peace of mind. Mine is not a daily driver though! 93 would cost a fortune on a daily driver!!aaronlstiles wrote:I run cheap stuff in my 98 5.0 explorer, and I know it pings like crazy, I would hate to run that in my 93. Maybe 91, but not 87
- jstanley55
