Maybe new outer tie rods would help....I believe original Ford are still available.93-3928 wrote:Let me know how that steering works. I feel that 3928 is loose. It floats around a lot. However it only has 27,000 miles on it. Not sure how to address this. Put new shocks and struts on, helped. But probably need some input on this!
Tom
3928
Re: * What did you do to your Cobra today? *
It felt really loose also..i have been driving my sons terminator and loved the way it feels so decided to upgrade since i was gonna do a rack any way. Once aligned i will let you know,noac wrote:Maybe new outer tie rods would help....I believe original Ford are still available.93-3928 wrote:Let me know how that steering works. I feel that 3928 is loose. It floats around a lot. However it only has 27,000 miles on it. Not sure how to address this. Put new shocks and struts on, helped. But probably need some input on this!
Tom
3928
- 93Cobra#2771
Castor/camber plates and an alignment to Steeda's specs did wonders for mine. A 20yo car and old technology makes our old cobras feel like the ss minnow compared to newer stuff today. Lol
Thanks guys. Keep the suggestions coming!
Tom
3928
Tom
3928
Absolutely! My Cobra has Steeda cc plates, Tokico 5-position adjustable front struts & rear shocks, Bilstein rear axle dampers and Steeda upper & lower rear control arms and holds its own in the handling department. Tightening up the car's chassis with subframe connectors and a strut tower-cowl brace would make a noticeable difference as well.93Cobra#2771 wrote:Castor/camber plates and an alignment to Steeda's specs did wonders for mine.
- 93Cobra#2771
I have the tokico 5 way adjustables as well.
Put some fresh air in the new gatorbacks, took it to get it inspected, 400 miles put on her in the last 3 years....
Finally rewired the Fog lights. Now they are on its on relay: works with the parking lights and also will go off when hi beams are applied. Just like stock except for no hot light switch and fogs with parking lights.
Update on the steering: This 03 steering rack is great, more feed back, solid feeling, no slop, but a little stiff (guess i can live with that). She still wanders, not as bad, but that's probably the tires.
I'd love a "how to" or pictures! My 89 has had the" lights-cutout" issue since the 90's. I just stopped using the fogs. When I restore the car, I need to fix this problem.Psychokinesis wrote:Finally rewired the Fog lights. Now they are on its on relay: works with the parking lights and also will go off when hi beams are applied. Just like stock except for no hot light switch and fogs with parking lights.
Goose17 wrote:I'd love a "how to" or pictures! My 89 has had the" lights-cutout" issue since the 90's. I just stopped using the fogs. When I restore the car, I need to fix this problem.Psychokinesis wrote:Finally rewired the Fog lights. Now they are on its on relay: works with the parking lights and also will go off when hi beams are applied. Just like stock except for no hot light switch and fogs with parking lights.
Thank you!Psychokinesis wrote:Goose17 wrote:I'd love a "how to" or pictures! My 89 has had the" lights-cutout" issue since the 90's. I just stopped using the fogs. When I restore the car, I need to fix this problem.Psychokinesis wrote:Finally rewired the Fog lights. Now they are on its on relay: works with the parking lights and also will go off when hi beams are applied. Just like stock except for no hot light switch and fogs with parking lights.
Update. Steering rack works great. Still have a little wander but 90 percent better. Solid steering feel. My son says he loves the way it feels now.93-3928 wrote:Let me know how that steering works. I feel that 3928 is loose. It floats around a lot. However it only has 27,000 miles on it. Not sure how to address this. Put new shocks and struts on, helped. But probably need some input on this!
Tom
3928
New (NOS) ECU put in. Smiles all day
It's over 60 degrees in the East today, so a Sunday morning drive was required. Nothing like 400+ horsepower to shatter the winter doldrums!
