Got my motor to the Dyno
Posted: Fri Jul 13, 2012 3:16 pm
by GTJay99
http://www.youtube.com/watch?v=MPhs6UM8 ... ture=g-upl
I had a motor built for my notch. Built a 347 N/A motor. Just got it to the dyno last week....
Posted: Fri Jul 13, 2012 5:00 pm
by BrettT
Sounds good.
What's the setup? heads,cam, etc..
Posted: Fri Jul 13, 2012 8:18 pm
by drtymike
Yeah, what's the setup, compression, etc etc...sounds nice.
Posted: Fri Jul 13, 2012 9:09 pm
by RollTide93
Over 400 lb ft of torque! very nice!
Posted: Fri Jul 13, 2012 10:38 pm
by GTJay99
Has dart pro 1 heads. Prolly around 11.1 compression with dome pistons. Custom ground cam. Quickfuel 850 carb, super victor intake. Problem was I started to build a mild motor and then one thing after another it's making 550+. Was still making power and shut it down at 7200. Here's the kicker. My mild to wild build is a stock block. Sooo, lets hope for the best. If I'd known the route I was going there would have been a dart block. But since the build was already 1/2 done, I went with what I had. Plus side is the entire motor is internally balanced and balanced very well. So it should stay together for awhile till I get a dart block for it. It really helps when it is on a good tune also.
