Looking 4 help getting the bolt that holds the struts off
The one that in the middle of the cast chamber.It spin n want break free I have replaced the back shocks need help on struts?
You need to remove it from the spindle on the lower section, and take the three nuts loose off the top of the strut mount.
Pretty much the same thing just on a newer model: http://www.youtube.com/watch?v=3UY-RzHCzWA
In order to change the whole strut you have to remove the whole thing.
When I changed mine out I had them off the car and put a little heat on them. Used a screw driver and a boxed end wrench. Worked fine but all I needed was the dust cover so I didn't care if I screwed them up or not. But it didn't harm anything
