Cobra Jet wrote:
Interesting reply about the A9L vs the X3Z parameters.
I was also thinking or should I say wondering if the REMAN'd X3Z's were possibly reworked A9L internals completed by the supplier to Ford (which may be the reason for the different labeling)?? Not sure if that makes sense to anyone, but I'm really curious to know where the REMAN'd X3Z's originated from....
Internals are identical, it's the programming that is different. And that programming is accessed through the port on the side. Of course, could have been something on the board that died, or whatever.
I'm pretty sure that when or if an ECM was replaced by and at the Ford Dealer - the unit would be another brand new unit, not one with "REMAN'd" labeling. I recall buying new A9L's back in the day and those never had a REMAN label.
True, up to a point. That point being when they run out of NOS of them. So then, they get into revamping existing units, or simply having a new production run done. I imagine revamping existing to be the less expensive option.
What is interesting too is both a REMAN and non-REMAN X3Z ECM's both come sealed with the same gray Ford decal (like all other original ECMs) that reads:
"Warranty Item Do Not Open" (Ford)
Tells me that it is most certainly a reman Ford unit (you can get reman units that are not Ford now). My guess is that Ford didn't want to pony up for a full production run and decided to fix what they had. Believe it or not, the EEC is a very robust design. Very few of them truly fail. And sometimes, they were replaced when they weren't necessarily at fault.
