check oil light
- Mustang Enthusiast
or you can take a power drill, with a LONG drill bit, aim it straight towards the light, and let the drill take care of the light issue. You might hear a "pop" and then you will have no light on your dash. but the bad part is.. you will end up with a drill hole in your cluster.
Question for ya, DB. How many points do they deduct for a hole in your dash?dbrennancobra wrote:or you can take a power drill, with a LONG drill bit, aim it straight towards the light, and let the drill take care of the light issue. You might hear a "pop" and then you will have no light on your dash. but the bad part is.. you will end up with a drill hole in your cluster.
once they see a hole in your cluster, they walk away... ask vinn.Z282SLO wrote:Question for ya, DB. How many points do they deduct for a hole in your dash?dbrennancobra wrote:or you can take a power drill, with a LONG drill bit, aim it straight towards the light, and let the drill take care of the light issue. You might hear a "pop" and then you will have no light on your dash. but the bad part is.. you will end up with a drill hole in your cluster.
True dat wiggasdbrennancobra wrote:once they see a hole in your cluster, they walk away... ask vinn.Z282SLO wrote:Question for ya, DB. How many points do they deduct for a hole in your dash?dbrennancobra wrote:or you can take a power drill, with a LONG drill bit, aim it straight towards the light, and let the drill take care of the light issue. You might hear a "pop" and then you will have no light on your dash. but the bad part is.. you will end up with a drill hole in your cluster.
