Funny you mentioned the spout. I pulled it and it passed on all (hydrocarbons etc..) but still fails on CO. With the spout in it fails everything.408lx wrote:To get my 408 to pass I use this recipe. Four gallons premium feul mixed with 600ml of gasoline antifreeze. Raise the idle to no more than 1250rpm. Tps at.98v. Fresh oil change. Bring it there nice and hot, and just before the test pull the spout on the distributor.
Failed Emissions Test
Re: Failed Emissions Test
Has anyone ever tried that guaranteed to pass stuff?
i wonder what would happen if you had an exhaust tip that was bigger than your pipe ? like the newer diesel trucks. so it would siphon fresh air before exiting the end of the pipe.
Is the testing different by county? Ive lived in Texas for twenty years and never had an emission test on a dyno? If nothing else works, Id put a stock h-pipe on it for the test.
That's what I said earlier, my county doesn't do emissions test, it only around Houston, Dallas, el paso, I think. Like a said he can ho to a non emissions county if he signs a waiver.psucobra wrote:Is the testing different by county? Ive lived in Texas for twenty years and never had an emission test on a dyno? If nothing else works, Id put a stock h-pipe on it for the test.
I'm going to try cleaning the air filter and MAF. Last resort I'll try to find a stock hpipe. Don't want to sign a waiver if it's not true. I live in the DFW area.
You mentioned your car is not a DD. If you've already spent $100 in repairs (or will do so) to attempt to pass emissions, you may qualify for the low mileage waiver. You'll spend way more than $100 to get a stock H-pipe.93svt#4558 wrote:I'm going to try cleaning the air filter and MAF. Last resort I'll try to find a stock hpipe. Don't want to sign a waiver if it's not true. I live in the DFW area.
http://www.dps.texas.gov/rsd/vi/consume ... nsions.htm
I called the DPS about this and they said since I just bought it I can't qualify under the low mileage waiver. I have to had driven it less than 5,000 miles in the previous 12 months. Thanks for the link.Z282SLO wrote:You mentioned your car is not a DD. If you've already spent $100 in repairs (or will do so) to attempt to pass emissions, you may qualify for the low mileage waiver. You'll spend way more than $100 to get a stock H-pipe.93svt#4558 wrote:I'm going to try cleaning the air filter and MAF. Last resort I'll try to find a stock hpipe. Don't want to sign a waiver if it's not true. I live in the DFW area.
another forum i'm on , the guys all know inspectors, and they and their friends never fail... lol go to dfwstangs and ask around , i bet you can find someone that will do it,
Damn! I thought the Northeastern states were tough on emissions. Apparently, it's worse down in Texas!93svt#4558 wrote:I called the DPS about this and they said since I just bought it I can't qualify under the low mileage waiver. I have to had driven it less than 5,000 miles in the previous 12 months. Thanks for the link.Z282SLO wrote:You mentioned your car is not a DD. If you've already spent $100 in repairs (or will do so) to attempt to pass emissions, you may qualify for the low mileage waiver. You'll spend way more than $100 to get a stock H-pipe.93svt#4558 wrote:I'm going to try cleaning the air filter and MAF. Last resort I'll try to find a stock hpipe. Don't want to sign a waiver if it's not true. I live in the DFW area.
Just ride dirty for a yr then get it exempted
I like that.bdecoy wrote:Just ride dirty for a yr then get it exempted
- 93svt#2779
Arizona is rough as well, but I think places in Cali are the worst!Z282SLO wrote:Damn! I thought the Northeastern states were tough on emissions. Apparently, it's worse down in Texas!
It finally passed. I had someone run a cleaner in the engine to loosen things up and pulled the spout again. The CO went down to .30 from 1.08. We are required to have .69 or better. I am so relieved.
Glad to hear that man, congrats!!!
92 GT white on grey leather
89 LX notch black on grey 408ci efi
93 Cobra red on leather #468
