3.55 vs 3.73
3.55 vs 3.73
I posted a question about this before, but didn't get any good advice. I want to hear from people with 3.55 gears and 3.73 gears in their cobras. Is 3.73 to steep for street? Do you feel you lose 1st gear? which gear is better for a weekend driver? Is there a big difference between the two? Do I need to purshase a installion kit for the shop to put in the gear? Any advice is appericated.
You will need more than just the gears to do a correct install, but a good shop will have all they need to do it.
373's are a bit much and 1st gear will be close to useless.
Its 2 or 3 sizes up from the stock 3.08 gears to the 3.55 gears.
You will notice a difference.
If fuel mileage wasnt a problem it wasnt driven as a daily driver then I would uses 3:73's
I would definately go with 3.73's. 3.55's are perfect for regular 5.0's. My 89 had them and they were great on the highway. With a slightly higher RPM motor in the Cobra, 3.73's are a match made in heaven. I have 4.10's now that the previous owner put in and they are a bit much. But even those aren't too bad on the highway. Get 3.73's, have the traction loc rebuilt at the same time if it needs it, and you'll have a new car. If you get 3.55's, you'll regret that little extra that you're missing.
'93 Cobra #220- Black over Gray Cloth- 4.10's, Long Tubes, 57K miles- SOLD 8/8
'06 GT- Windveil Blue over Light Graphite Leather- 5spd
'93 Notch- 144k miles
I just thought of something that may be an issue for you. When doing a gear swap, you also need to install a new speedometer gear in the trans to correct the speedo. It's very easy to do. However, and correct me if I'm wrong, on 90-93 Mustangs transmissions, the speedo CANNOT be corrected beyond a 3.55 with simply a speedo gear swap. It is a more involved process to correct the speedo when using 3.73's, 4.10's, etc. The aftermarket may have fixed this problem by now, but I'm not sure. Just something to consider...
I thought people had posted what gear color to use on the other site.
