Motor turns over but fuel pump does not come on when I turn the key, the pump does work I pull the tank out and it works. There's a switch in the trunk of the car not sure if it is to be pressed down or not earthier way still does not start. Any suggestions on what my problem is. I haven't tried to started the car from about 3 weeks
Scott
fuel pump not working
Re: fuel pump not working
DID YOU PROVIDE YOUR OWN POWER AND GROND TO MAKE IT WORK OR DID YOU USE THE FACTORY WIRING ?stock2262 wrote:Motor turns over but fuel pump does not come on when I turn the key, the pump does work I pull the tank out and it works. There's a switch in the trunk of the car not sure if it is to be pressed down or not earthier way still does not start. Any suggestions on what my problem is. I haven't tried to started the car from about 3 weeks
Scott
they moved the relay to the pass side inner fender well behind the air cleaner. There is 2 relays there. One is the wide open throttle relay, and the other is the fuel pump relay. The reason they moved it is for the power seat motor. My 89 Gt had it under the seat also. Did you check that fuel pump shut off switch in front of the drivers side taillight?
