93 Cobra not starting?????
- 93KingCobra
I dont ask too many questions around here but my car is really thrown me for a loop......
The other night I was driving home from dinner and it dyed on me on the freeway and I had to get towed home..
Well today I got a chance to check it out and I was looking around and found out that the rotor had melted the tip under the cap. So I went and bought a new cap and rotor and replaced it but it still will not start. I have also check the timing ,plug(when I did check them #5 had a little gas on the tip),vacume leaks,and for some strange reason in between trying to start it I put my hand on the grond wire of the battery and it was extreamly hot??
What do you guys think it might be???? I am really lost and any help you can give me would be great..
Thanks
Phillip
Thanks
Phillip
1993 Cobra Black #4265 of 4993 Born on 6/9/1993 SOLD
http://www.svtcobraclub.com
If the ground is really hot then there is either a ground issue or the starter solenoid could be a cause for concern. You could also have over heated the wire by many attemps to start the engine.
Does it crank ?
Does it have spark ?
Does it have good fuel pressure
Does it crank ?
- 93KingCobra
BADBOYSPACK wrote:If the ground is really hot then there is either a ground issue or the starter solenoid could be a cause for concern. You could also have over heated the wire by many attemps to start the engine.
Does it crank ? YES
Does it have spark ? YES
Does it have good fuel pressure YES
I was thinking that when he said he was driving and it stalled on the highway.black93svt wrote:Did the ignition module on the distributer go bad?
The usually restart after they cool down.
I was wanting all the info before I told him that.
- 93KingCobra
Not yet..I will have to look at it this weekend..CobraStrike93 wrote:have you had any luck yet????
You know he will.CobraStrike93 wrote:Sounds good let us know!!!!
