Grinding in 5th
Posted: Fri Apr 06, 2012 3:37 pm
by jstanley55
Driving back from so cal last night and everytime I shifted to 5th I get a little grind. If I double clutch it everything slides right in no problem. I am thinking syncro's but a friend mentioned maybe a bent clutch fork. Figured I'd see what the consensus is here...
Re: Grinding in 5th
Posted: Fri Apr 06, 2012 3:50 pm
jstanley55 wrote:Driving back from so cal last night and everytime I shifted to 5th I get a little grind. If I double clutch it everything slides right in no problem. I am thinking syncro's but a friend mentioned maybe a bent clutch fork. Figured I'd see what the consensus is here...
A fifth sycro would be very, very odd. The norm is 3rd. Not saying it couldn't be, but not the usual suspect. Either way, sounds like it needs to come out.
Posted: Fri Apr 06, 2012 4:25 pm
Original or aftermarket clutch? What about the self adjuster, or the adjustment of the clutch?
Posted: Sat Apr 07, 2012 10:24 am
by jstanley55
WillyB93 wrote:Original or aftermarket clutch? What about the self adjuster, or the adjustment of the clutch?
I am sure it's aftermarket. Would it being out of adjustment effect just 5th?
Re: Grinding in 5th
Posted: Sat Apr 07, 2012 10:53 am
by RollTide93
I know of a quality tranny shop, Ha!
Re: Grinding in 5th
Posted: Sat Apr 07, 2012 11:36 am
by jstanley55
RollTide93 wrote:jstanley55 wrote:Driving back from so cal last night and everytime I shifted to 5th I get a little grind. If I double clutch it everything slides right in no problem. I am thinking syncro's but a friend mentioned maybe a bent clutch fork. Figured I'd see what the consensus is here...
Funny I was already thinking I need to call your uncle on Monday and get a quote if I bring him the tranny. It's been loud for a while so I figure a it's time for a good rebuild.
Posted: Sat Apr 07, 2012 11:42 am
I wouldn't think so, but I would be checking everything before tearing it out.
Re: Grinding in 5th
Posted: Sat Apr 07, 2012 11:59 am
by RollTide93
jstanley55 wrote:RollTide93 wrote:jstanley55 wrote:Driving back from so cal last night and everytime I shifted to 5th I get a little grind. If I double clutch it everything slides right in no problem. I am thinking syncro's but a friend mentioned maybe a bent clutch fork. Figured I'd see what the consensus is here...
I talked to my uncle so if you do decide to go that route he knows you might be stopping by
Posted: Tue Apr 10, 2012 10:10 am
by 93Cobra#2771
My T5Z would do that if I ran through the gears and shifted into fifth about the time I let out of it (say 90-100 mph).
Regular driving its never done it.
