windshield and hatch trim clips
When you guys pull the trim to paint the trim do you replace the clips that hold the trim on? Curious who you guys are getting the clips from and if they are any good at holding the trim tight once replaced. I just pulled all my trim and some of the clips took a beating so I would think it's best to replace them. LMR has the long clips for the back which are similar to the stock ones so I would think those would be what I want and they have windshield clips from 5.0 resto that I'm curious if they are any good.
1993 Cobra- Teal w/gray cloth #1113(SOLD)
67000 miles
67000 miles
if you use the correct tool , or similar, you can reuse the clips over and over. with no damage, the only reason i have ever replaced a clip was sue to rust. I remove mine occasionally to wash the dirt that builds up behind the mouldings , to prevent rust. You can the tool at Harbour frieght if you need it , comes in a set. third from left
I have the tool and I'm sure the clips can be bent back into shape but was curious if they loose the ability to hold the trim tight. The tool took getting used to. I had to grind down the tips so they were a bit sharper to grab the clips plus some of the clips were buried in the window gasket/sealer making it difficult to get behind them.
67000 miles
67000 miles
If you do need some new clips, check your local body shop paint store they should have them.
LMR sells them: http://www.latemodelrestoration.com/pro ... dy-Molding
-Darrell
2003 BMW M3 Coupe
93 Cobra #199 - SOLD
2003 BMW M3 Coupe
Re: windshield and hatch trim clips
TTT
