Replacing rear main -new clutch?
MJH
Post by MJH »
I am replacing the rear main seal next week, the car has 51k on it should I go ahead and replace the clutch? The clutch still feels great and there is no noise coming from it. If I should replace it what clutch should I go with?
1996 Saleen S281 Rio Red/Black Vortech (SOLD)
1993 Red/Leather #2588 (SOLD)
1995 Cobra White/Black #467 19K (SOLD)
Best thing to do, is just look at it once you have it out, also use a Ford rear seal, Best clutch is the king cobra for a replacement. My local Ford dealer has a few left in stock, as they are discontinued now.
The last one I got from ford was a fel-pro seal
I just replaced my rear main seal and got it from latemodelrestoration.
No more oil leaking but now I have a small amount if tranny fluid leaking- never fails
Damitt, my rear main seal is leaking again wtf
Sometimes the crank flange will have a groove worn in it and a new seal won't fix it, but they sell a repair sleeve that you drive on the crank.
Are you draining both drain plugs, and also may want to put a new PCV Valve in it, they tend to get block up, causing some crank case pressure.
As for the King Cobra CLutch my buddy has a few left in stock, Ford no longer makes them or carries them in stock.
Also A Ford rear main seal is the only way to go. Autozone seals work for a while, but Have seen many leak after replacing a few weeks/months
I have also seen grove in the crank, but mostly on really high mile cars.
MJH
Post by MJH »
How much do the clutches go for? Also why does the ford seal work better? Drain both plugs?
aaronlstiles wrote:Are you draining both drain plugs, and also may want to put a new PCV Valve in it, they tend to get block up, causing some crank case pressure.
I didn't do it a shop I use did it. Problem is should I have to pay the whole labor rate again?
It was a rear main from latemodelrestoration.
Where can I get a Ford rear main seal?
1993cobra wrote:Sometimes the crank flange will have a groove worn in it and a new seal won't fix it, but they sell a repair sleeve that you drive on the crank.
Could that be the case with 133k? I guess I will let him know if he hasn't checked already.
pete3323
Post by pete3323 »
King Cobra clutch kits are all over ebay.
'98 White terminated Cobra
'93 Black Cobra #4831
MJH wrote:How much do the clutches go for? Also why does the ford seal work better? Drain both plugs?
There is two drain plugs, one in the front and one in the back of the oil pan.
Why would that make a difference?
Here we go seems this horse has been beat and no one has a good answer-
http://forums.corral.net/forums/5-0-5-8 ... thers.html
Make sure the crank is smooth, oil the crank side of seal tap it in slowly and equally all the way around till its fully seated, , easy...
