Emergency brake handle
Snake93
Post by Snake93 »
Having a problem with Brake handle when I let it down it tends to let down to the left n rub the side of the console is there any way to tighten it up so it will let down straight?
#879 Blk,leather,sunroof
Grab it and pull it the way it needs to go, it will bend
Snake93
Post by Snake93 »
The whole mechanism moves, the bolts r tight
I think the spring in the handle ends up getting some play in it letting it lag to the left toward the drivers seat. Pretty common issue I have seen with these cars and GT's and LX's.
A lot of people would keep a drink wedged in between the handle and the passenger seat..... I could see that bending the handle out of whack and towards the driver seat. :lol:
Snake93
Post by Snake93 »
Yea I think it is play n the spring I guess I will have to replace the whole brake leaver with it being one piece ,what the best place to get one n best $
Is it rubbing the console or just the rubber piece? They sell replacement seals if it is damaged. Kinda a PIA to replace since they plastic welded it to the console.
https://www.foxresto.com/products/view/ ... ubber_Seal
Snake93
Post by Snake93 »
Rubbing console all ready replaced rubber trying to avoid messing rubber up again
Just pull it out, and look it over, i believe a 94 - 04 brake assembly will work, if you can't fix yours
Snake93
Post by Snake93 »
Ok thanks guys
