Aaron i hope so... how hard is the rear main or front seal? how long to do?aaronlstiles wrote:D, I seriously doubt it, the oil pan gasket, is a rubber over steel gasket, unless your car is high Mileage, it is more than likely the rear main, or the front seal, it could also be coming from the oil dip stick where it goes in the block.
Less labor hours than replacing a heater-core. I don't think DB will be working on his own car, sounds like he is estimating per labor hour.buddha wrote:X2 to what Aaron said.
And it's worse than replacing a heater core, if that tells you anything.
i have a baby on the way, so time doing this will not happen now... but i want it done. so im hoping less than a days work... ill check the bolts first of courseRomo93 wrote:Less labor hours than replacing a heater-core. I don't think DB will be working on his own car, sounds like he is estimating per labor hour.buddha wrote:X2 to what Aaron said.
A HUGE congrats to you & your growing family, Don!!! That's awesome news!!dbrennancobra wrote:I have a baby on the way.
not yet... i think it may be the rear main or front seal..Romo93 wrote:DB - You figure out the oil leak?
