Can't get bolt on top of struts off
Posted: Thu Jul 04, 2013 6:14 pm
by Snake93
Looking 4 help getting the bolt that holds the struts off
The one that in the middle of the cast chamber.It spin n want break free I have replaced the back shocks need help on struts?
Re: Can't get bolt on top of struts off
Posted: Thu Jul 04, 2013 10:09 pm
by escogt
An impact gun will usually do the trick.
Posted: Thu Jul 04, 2013 10:14 pm
by Snake93
The nut n shaft turns when u use a impact gun r wrench
Posted: Thu Jul 04, 2013 10:15 pm
You need to remove it from the spindle on the lower section, and take the three nuts loose off the top of the strut mount.
Pretty much the same thing just on a newer model:
http://www.youtube.com/watch?v=3UY-RzHCzWA
Posted: Thu Jul 04, 2013 10:19 pm
by casper
grab piston with vise grips, if you are replacing they.
vise grips on new, unless very high up.
Posted: Thu Jul 04, 2013 10:27 pm
by Snake93
Is there a way to just take the bolt off with out removing the whole assembly
Posted: Thu Jul 04, 2013 10:51 pm
In order to change the whole strut you have to remove the whole thing.
Posted: Fri Jul 05, 2013 11:41 pm
by Mike S.
Use a Powerful impact gun, like an Ingersoll-Rand, not a Craftsman or off brand chinese. Should come right off without spinning the shaft.
Posted: Sat Jul 06, 2013 7:45 am
And make sure you have good air volume and at least 90 psi .
Posted: Sun Jul 07, 2013 4:58 pm
by POOBLAH
You could always try a NUT SPLITTER ... :-/ It could damage the threads on the Strut if your not careful.
Posted: Sun Jul 07, 2013 7:50 pm
by 93N8
When I changed mine out I had them off the car and put a little heat on them. Used a screw driver and a boxed end wrench. Worked fine but all I needed was the dust cover so I didn't care if I screwed them up or not. But it didn't harm anything
