a/c vent sticking?
a/c vent sticking?
so I was going to pick wifey up from the house and went to turn the a/C on in the Cobra :drive: (the only time the a/c gets turned on BTW) and the only positioned it will only blow air is from the defrost position, thinking something blocking the air from flowing in the front somewhere in there? :?
Re: a/c vent sticking?
Could be a possibility that something is blocking the flap, or the controls are vacuum activated, most likely your problem.
jstanley55
Post by jstanley55 »
vinchez78 wrote:so I was going to pick wifey up from the house and went to turn the a/C on in the Cobra :drive: (the only time the a/c gets turned on BTW) and the only positioned it will only blow air is from the defrost position, thinking something blocking the air from flowing in the front somewhere in there? :?
Yeah check your vacuum lines. I had the same exact problem and it was a broken vacuum line.
Gracias fellers, I'll check it out this weekend
