I have a question on emergency brake cable routing, I know for the 93's there is a bracket in the trans tunnel that the e brake cable attach to, then how are routed back to the rear disks?
Any one have their car on a lift and can take a few photos of how the cable attach from the the bracket back to the rear. Looking for routing and attachment points.
Thanks
Rear disk brake question
Re: Rear disk brake question
Can anyone take a quick look, trying to see how the ebrake cables are run from the tunnel bracket to the rear, any other brackets?
Thanks, any help would be great.
Here's a couple pics of mine from a while back.
Not the best angle, hope they give some idea.
GL
GL
Just want I needed!!!
Thanks, attaches to the contol arm.
is there another braket near the end of the trans tunnel by the diff?
From the control threw the control arm box, then threw a bracket above the muffler them above the drive shaft to e-brake. Not the best pics, car was on the ground and I used my phone to the pics and also post here. Again hope it helps.....pm me your number if u want further assistance.
- 93svt#2779
As always, Brett has gone above and beyond the call of duty.
Your the Man Brett!!
That is what I needed!!!!
Thank you
Thank you
