Timing - Finally got the 93 back together...
Posted: Fri Sep 06, 2013 10:15 am
by HMGARCIA
So , After one month, the cobra is back together. Now, I need help with the timing. Does anyone have any info on
how to do this ?
I have a timing light. - Just need help!
(( diagrams, pictures, step by step etc.. ))
Thanks ,
Re: Timing - Finally got the 93 back together...
Posted: Fri Sep 06, 2013 3:49 pm
by Romo93
HMGARCIA wrote:So , After one month, the cobra is back together. Now, I need help with the timing. Does anyone have any info on
how to do this ?
Thanks ,
Google it and I'm sure you can find a few videos, not hard at all.
Posted: Fri Sep 06, 2013 3:55 pm
by 93svt#2779
Not sure if this is what your looking for... if not there are other videos on you tube that might be helpful...
http://www.youtube.com/watch?feature=pl ... qVzHmpSdsk
Posted: Fri Sep 06, 2013 7:29 pm
Basically you remove the timing spout connector, set the timing then replace the plug.
Posted: Thu Sep 12, 2013 4:06 pm
by HMGARCIA
So. Turns out the 93 Teal that i purchased with half the motor ripped out WORKS.
It took me a month to put it all back together, but it starts and runs.
Now :
I think its leaking from the rear main seal ( only pulled out less than a qt. of oil when i changed it )
The steering is really sloppy
Dash lights dont work
Door actuators dont work
Transmission is fine. ( loooonnnnngggg shifter though )
Not to mention interior and ground effects / wheels and rear end are NOT factory, they are rerpo -
( as mentioned in other posts..)
I feel like i got a good deal , and i am HAPPY !
Little by little this car will be turned factory correct
Posted: Fri Sep 13, 2013 11:11 am
by vinchez78
Good luck with the cobra bro, keep it up
