Center Console Repair?
Posted: Mon Nov 04, 2013 7:36 pm
by jstanley55
So I picked up a nice OE CD player and some extra floor mats from our friend rolltide last weekend and I'd like to install the radio but I have 4 wonderful holes in my console from the aftermarket radio install. Has anyone ever filled and sprayed the radio portion (black upright part) of their console? If so, what did you use and how'd it turn out? I really don't want to buy a new console as the rest of mine is perfect.
Re: Center Console Repair?
Posted: Mon Nov 04, 2013 8:35 pm
I used this:
http://www.jpcycles.com/product/606-491 ... Mwod_wkA2A
It's already black to boot, but you can still spray the radio side,up to where it meets the bottom of the console. Stuff works pretty darn well. If you really take your time, it's hard to see where the holes were. Mine could have turned out better, but I'm happy with the results. FYI, the liquid part of the mix has no problem in melting existing plastic, so be careful with it if you decide to give it a try.
Posted: Mon Nov 04, 2013 8:47 pm
by Romo93
Is it like a plastic bondo, Or is it hard to work with? Pretty cool product if it is.....
Posted: Mon Nov 04, 2013 9:06 pm
by jstanley55
Thanks Buddha! I'll order some and how it all goes good!
Posted: Mon Nov 04, 2013 9:14 pm
Instead of a 2 part epoxy, it's a powerder and urethane. This vid gives you an idea of how it works:
http://www.youtube.com/watch?v=stO4pDw4L94
This is on the extreme side with filler and sanding, all of which you should'nt need to do with filling the holes with the powder/liquid mix. There is a a blue rubber-like molding piece that will allow you to transfer a pattern over onto the plastic before it cures. Not hard to use, just need to take you time, experiment with it a bit on the side do get an idea of cure time, etc.
