Determine what parts to keep after repairing your Cobra
Posted: Sun Jan 05, 2014 1:32 am
So as some of you might know, I just finished rebuilding my entire front suspension. I fixed alot of problems, but now I need to determine what parts to keep and which can be pitched. From a collect ability standpoint everyone wants our cars to be as original as possible. So what do I keep?
Heres what I have left from the build:
Lower Front Control Arms:
*Passenger side has a bad ball joint and worn bushing
Replaced with Ford Racing Lower Front Control arms (M-3075-A)
Front Springs:
*Passenger side was weaker and created a lean in the car
Replaced with new takeoff 93 Cobra front springs
Front Spring Isolators:
*Typical Wear
Replaced with Ford OEM isolators both top and bottom
Struts:
*Not original equipment
Replaced with 03-04 Mach One Tokico Ford Struts
Brakes:
*Obviously not original
Replaced with Hawk Ceramics
Sway Bar Bushing:
*Cracked and worn originals
Replaced it with Polyurethane Moog bushings.
Sway Bar Links:
*Typical wear, slightly bent on each where the sway bar connects
Replaced with Ford OEM links
Things I wasn't planning on keeping were the Sway Bar Links, Bushings, Brakes, Struts, Spring Isolators
I'm kinda up in the air about some of the other things.
What do you all think? What do you look for in a higher mileage car or one that has been restored?
Front Springs:
*Typical Wear
Struts:
Brakes:
Sway Bar Bushing:
Sway Bar Links:
