Idle issue
Tunedout
Idle issue
Post by Tunedout »
I changed injectors and fuel pump to walbro 255 car cranks right up now. But idle is off it goes up and down. Maybe vacuum leak. I've changed a few hoses. And fuel filter . Maybe bad sensor but no (ses) on. Any thoughts .
1993 cobra #4904 teal
1987 Buick grand national
1999 Pontiac trans am ws6
2005 Suzuki gsxr 600
2000 chevrolet camaro ss
Re: Idle issue
Did you re use the old plentium gasket or buy new? More then likely a vacuum leak or bad plentium gasket, had the same issue on an older one I had ended up being that gasket.
Re: Idle issue
Same size injectors?
Re: Idle issue
I had an idle problem before and took it on the highway and drove it like I stole it, idled back to normal after that :drive:
Re: Idle issue
I agree on the gasket leak. They can be a bitch to find sometimes.
Can even be as simple as cleaning your throttle body and mass air meter. Might as well check your TPS voltage as well.
redsvt
Re: Idle issue
Post by redsvt »
sounds like it needs to relearn how to idle. and also the IAC my need cleaning. if that doesnt work spray brake clean around the gaskets and vacuum lines and listen for idle change.
Blaine
2003 Lightning
1991 Coupe(pearl)
1993 Cobra(Fire crotch)
1991 hatch GT(menace to society)
1989 Saleen SSC(wachootoo-white devil)
