Looking to upgrade maf on supercharged cobra...
What do y'all recommend since we have to use mafs specific to our computer... so far all I see is pro m 75mm and granatelli 90mm
Re: Looking to upgrade maf on supercharged cobra...
Pro M has an 80mm & 92mm as well for the '93 Cobra. Pro M is what I'd recommend.
Excellent recommendation. I'm using an 80mm MAF. Works great.escogt wrote:Pro M has an 80mm & 90mm as well for the '93 Cobra. Pro M is what I'd recommend.
X2 ^^^ on both comments
Thanks! Will look for an 80mm pro m!
Well looking at the big ass bell mouth flange on the pro m 80mm, looks like it won't be small enough to be used with the vortech airbox? I am running that right now and don't plan on using a power pipe or really upping the boost. Just need something more efficient than stock?
Would the 75mm still be a good step up from stock since I can fit it in the stock location and have it calibrated for a supercharger? I am only running 5-6 psi and don't plan on upping that at all.
I would say yes to this. Today's MAF's are a step up from the 20 year old technology MAF's like those in the '93 Cobra.Dixie789456 wrote:Would the 75mm still be a good step up from stock since I can fit it in the stock location and have it calibrated for a supercharger? I am only running 5-6 psi and don't plan on upping that at all.
escogt wrote:Dixie789456 wrote:I am only running 5-6 psi and don't plan on upping that at all.
If your only running 5-6psi.
IMO, I would save the money and keep the stock mass air on. Your not going to gain or benefit from anything bigger.
X2 considering the mild set-up you're running.BrettT wrote:IMO, I would save the money and keep the stock mass air on. Your not going to gain or benefit from anything bigger.
Ok thanks! Yeah it runs really well right now... even better than when I got it and it was all stock
I guess installing 3.73's in it this week will give it all the extra bump I need
no need to install parts the may or may not make any difference.
Does the car have a tune?
Maybe an aluminum driveshaft would be a better buy since I get slight vibes at higher speeds and rpms out of my stock one?
No tune, just running fmu, 155lph pump, and sp505 plugs gapped to .035.BrettT wrote:Does the car have a tune?
Shorter rear gears are without a doubt one of the best bang for the buck (and noticeable) mods for a Fox body Mustang.Dixie789456 wrote:I guess installing 3.73's in it this week will give it all the extra bump I need
