The car has been sitting for the past 9 years. Car runs great with no issues. Recently reconditioned to get it back on the road. Had it repainted the original Vibrant Red. 107,000 miles
Items replaced in the past few months:
New tires, Windshield, A/C compresser and lines, serpentine belt, radiator and coolant hoses, oil pressure sender, battery, air filter.
Mostly all stock with a few aftermarket parts including Hurst shifter, lower control arms and
flowmaster cat back exhaust.
I've owned the car for 6 years and have only driven it a few hundred miles. I have noticed the speedometer reads 10 miles above actual speed. Could use a few maintenance items addressed like brake fluid and coolant flushed. I had a used factory cat'ed H-pipe installed so the car will pass emissions.
I have a clean washington title. Car has not been tabbed since June 09. Also have Marti report, car fax and SVT certificate from Ford Motor Company.
If you have any questions give me a call. thanks. Mike 206-778-8950
