#1296 1993 SUPERCHARGED FORD COBRA FOR SALE
1993 Ford Mustang Cobra - $27,500 OBO
http://www.1993cobra.com/data.htm
VIN#1FACP42D5PF154880
Assembled at the Dearborn Assy. Plant on 04/02/93
#1296 of 4993
Miles – 28,500 documented miles
Color - Teal
Condition – immaculate
Bought car from owner in Southern Ohio with all documentation
Car runs absolutely perfect with no issues at all – will give a limited warranty with car
Information
Ø Never been in accident or in rain/ snow
Ø Underbody coating
Ø All original paint
Ø Car is immaculate without a scratch/ dent or rust anywhere
Ø Stored in a heated garage and has never been abused
Ø Have all stock components so car can be returned to stock
Ø Interior has no rips/ tears/ stains etc… still smells new
Ø Grey leather interior w/ power seats
Ø All power seats and other power equipment work perfectly (recently replaced driver side power seat track – have old track)
Ø HAVE RECEIPTS SHOWING OVER $15,000 WITHIN THE PAST 3 MONTHS
Ø Dyno tuned by Lidio 420HP/ 431 ft/lbs torque (have graph)
Ø ALL WORK PERFORMED BY LIDIO IACOBELLI OF ALTERNATIVE AUTO PERFORMANCE (ALTERNATIVEAUTO.COM)
Ø HAVE ALL RECEIPTS AND MILEAGE VERIFICATION OF WORK DONE
Ø ALL WORK WAS PERFORMED AND COMPLETED WITHIN THE LAST 300 MILES
Ø NO EXPENSE SPARED ON THIS CAR – IF LIDIO RECOMMENDED THAT IT WAS NEEDED THEN IT WAS DONE
Ø Bassani equal length shoty headers (ceramic coated)
Ø BBK x pipe (ceramic coated)
Ø Flowmaster mufflers w/ magnaflow stainless tailpipes
Ø Ford motorsport aluminum driveshaft
Ø Pro 5.0 shifter w/ steeda tri-ax handle (have multiple handles and knobs)
Ø Ford motorsport anniversary shifter boot
Ø Have 2 sets of original cobra mats with red cobra writing (never used)
Ø Ford motorsport 3.73 gears and pinion bearing (all bearings replaced)
Ø T/A Girdle cover (all new axle fluid)
Ø 31 spline moser axles w/ studs
Ø Eaton Posi (carrier bearings and races)
Ø Rear rims have been widened 1.5” by weldcraft engineering (weldcraft.com) to 9” (stock is 7.5”) to accept a 275 wide rear tire
Ø BF Goodrich Gforce TA tires (have 30 miles on them)
Ø All 4 factory rims have been powdercoated original color
Ø 2 new OEM FORD turbine rims with centercaps and tires come with sale BFG G force tires (never used)
Ø Custom laser cut rear wheel spacers
Ø Ford motorsport performance clutch (new bearings)
Ø Mega bite jr lower control arms (have stock)
Ø Pinion bearings and seals replaced
Ø Fuel filter
Ø Rear main seal
Ø New thermostat (160)
Ø Smog eliminator
Ø All belts replaced for reliability
Ø MSD plug wire set
Ø Poly sway bar bushings
Ø Rear quad shocks removed
Ø Maximum motorsports caster camber plates
Ø Front end aligned with a lifetime warranty
Ø Vortech satin V2-SQ supercharger (10 psi boost) (http://www.vortechsuperchargers.com/cat ... ERCHARGERS)
Ø 42 lb injectors
Ø 255 lph fuel pump
Ø 8 new spark plugs
Ø 3.1 pulley
Ø 90mm mass air meter w/ tube and silicone adaptor
Ø Ford racing aluminum radiator (have stock)
Ø EGR block off unit
Ø Stock non-tilt steering removed and tilt column was installed w/ MOMO wheel
Ø ALL Gauges are LED blue at night
Ø MSD programmable shift light
Ø Piller and vent gauges (Boost/ fuel pressure/ oil pressure/ water temp) – have OEM vents – no holes drilled so can be returned to stock
Ø Keyless entry
Ø Hidden security switch for start
Ø Fog light mod
Ø Light tint on windows
Ø Luxury car cover for storage by Coverking
Ø Alpine Stereo and speakers (over $3500 in receipts) within last 3 months – all can be removed with no damage to car
Ø Alpine head unit with IPOD adapter
Ø Have many extras that go with car but too much to list – call for details at 248-505-1530
Ø Please contact me at bradsterdragster@hotmail.com if interested for more info
#1296 of 4993
Color - Teal
Information
Ø Underbody coating
Ø Fuel filter
Ø Rear main seal
Ø Smog eliminator
Ø MSD plug wire set
Ø 42 lb injectors
Ø 255 lph fuel pump
Ø 8 new spark plugs
Ø 3.1 pulley
Ø Keyless entry
Ø Fog light mod
You would sell it quicker by putting it back to stock and selling off your parts. And probably get closer to what you want for it that way.
93 Cobra
I have to agree wih brandon on this one.
1993 COBRA FOR SALE
Price is OBO and is negotiable but your comments are well noted. I believe someone who is serious about purchasing this car will buy it after they look at it and see the condition and what they are getting for their money.
Ya think!93COBRAinAZ wrote:Good luck with the sale but I think your price is quite high.
93 cobra for sale
OK - HOW ABOUT $25,000 OBO???
93 cobra for sale
I would be willing to entertain offers in the 20-25K range!!!!
Re: #1296 1993 SUPERCHARGED FORD COBRA FOR SALE
Looks like someone returned it back to a somewhat stock form.
https://www.ebay.com/itm/1993-Ford-MUST ... :0&vxp=mtr
- 1986Browns
Quite the transformation, even put the stock airbag wheel back.
You guys are diffidently on point. Nothing seams to slip by.
Thought that was the same car when I saw it on Ebay.
