I have seen on more than one occasion recently- someone needed help posting pics.. I dont mind doing this for people, but i figured id take the 5 min to write this tutorial. "Dont give a man food, teach him to hunt" type thing. Although, im not a hunter.
ANYWAY-- the site i use is www.imageshack.us
The opening screen is this-
I like to have the image i am posting on the Desktop- so it is easy to find. You then hit the "browse" and a window will pop up for you to select a file.
MAKE SURE you hit resize image-- its default is the very small 100x75. I use 640x480
Once you have your pic and the resize checked- you will hit submit.
It will go to a progress bar (not pictured here) and then to this screen-- which i had to do in two pics. You can see it is all one screen.
At the very top= it says "direct link to image" in the yellowed bar-- this is for your offsite avatar. (i would have the image sized to about 220X220 pixels)
closer to the bottom, i have high lighted in blue, is where you get the code for your pic. You will copy this section "hotlink for forums 1" and paste it in your post.
Hope this helps!
