Dyno Pull before replacing the converter
yeah I have a walk around video it shows under the hood, when I bought the car it had a turbo kit on it, so there was some cutting on the engine bay ever, so slight, they did have to trim a LITTLE bit of the bumper support to get all the stuff to fit because I wanted to keep the AC, so its like a huge sandwhich of Fan(Pusher) ->Transmission Cooler -> Condenser -> Radiator -> Fan(Puller)psucobra wrote:That thing sounds nasty!!!! I would love to see some under hood pics. Did they have to do any cutting in the engine bay for the turbo setup?
psucobra wrote:I Love it!!!! That is a sweet setup. Congratulations!!!
Damn! Sweet car...Neoex wrote:psucobra wrote:I Love it!!!! That is a sweet setup. Congratulations!!!
Thanks, just had Freddy Brown go through my AOD to the tune of another $2900, but you cannot knock what the guy can achieve with an AOD. Its currently getting bolted back in (tomorrow) and then I am having Bob(Kurgan) add a tune for E70, because my local E85 stations are carrying 1 or the other depending on whichever way the wind blows /sighso I want to be able to test it and set my tune accordingly
Neoex wrote: I know there is more of a "keep it factory" crowd on this board, so go easy on me]
I wanted to send it to the best, so I shipped it from Tulsa to Georgia to have bob and team work on it. Electronics wise it has a Sequential FAST, setup with a Innovator West crank trigger setup, has 160 lb fuel injectors, huge magna fuel pump with sleeper tank. It has Maximum Motorsports adjustable suspension pieces, and on the 17" nittos I was EXTREMELY impressed (im a MT fan) how well it hooked, I didnt get to put many miles on it (pushed the front tranny seal out). But I was expecting it to really be wild even in 3rd gear, and it planted the power and took off like I never would of thought. I did have it on the low boost setting of 16lbs not 23, so I could acclimate myself, so figure it was making around 600-640 at that boost setting.buddha wrote:Neoex wrote: I know there is more of a "keep it factory" crowd on this board, so go easy on me]
I know not of what you speak. (See sig)![]()
I think the car is friggin' awesome. If Kurgan and crew got a hold of it, I'm sure it's a solid build.
So what did he tune with? SCT chip/MAF with stock EEC? What about the rear suspension? Got the goods to get the power to the ground?
Last time on the dyno @ 13.5 psi, it made right at 550 to the tires. I've since upped the boost, and added a little meth to the mix for good measure, but haven't had it back to the dyno since. Best guess would put it the neighborhood of 625 to the tires.Neoex wrote: What kind of power does that novi2k put down?
