1) When starting new thread or posting reply you see "add image to post" link below textarea:
Click Image to enlarge.
2) Click that link, popup will appear where you should select image and add description to that image (description is optional):
3) You click "upload it" link, image is uploaded and bbcode is automatically inserted in post: You can copy URL's from 'Craigslist Ads', 'Autotrader', 'Ebay', & from other forums and sites by RIGHT CLICKING over images.
4) You click "submit" to submit post and thumbnail of image appears in post (just like thumbnails posted above):
NOTE:
Not all images are compatible for upload, due to their file extensions or how they were uploaded from other sources. The best way to determine is to RIGHT CLICK the image, if you see "Copy image URL" in the small window box. Then image should easily be uploaded using the "Add image to post" link below the message test box. PICTURES WITHIN ALREADY EXISTING THUMBNAILS ARE NOT COMPATIBLE, CLICK THE THUMBNAIL PICTURE AND COPY THE 'URL' FROM THE LARGER PICTURE.
LOL! That SVT cert is a fake and the pic shows what looks like a modded GT vert with some Cobra parts. The VIN on the cert indicates a LX convertible (P44) and standard H.O. V8 (E). The engine code is the 8th letter of the VIN.
All Fox body Cobra VINs indicate a GT hatchback body (P42) and GT-40 V8 (D).
P.S. Admin/Moderator - the previous post and this response should probably be moved elsewhere.
NOTE*************************************
when you use "add image to post" and get the part where you can check "adult" or "family safe" always check "family safe , other wise the ads that pop up on the same page will be of an adult nature.
