Rear view mirror replacement/window question
Doughrat19
Post by Doughrat19 »
Anyone ever replace their rear view mirror? I bought a replacement because mine has a bunch of black spots on it. Just wondering what is the safest/easiest way to get the old mirror off the windshield.
On a side note, is it common for the power windows to not operate super smoothly? Don't get me wrong, mine go up and down no problem, they just aren't smooth like butter. It's hard to explain but they make a little screeching noise and wobble a little bit. Is there something I can replace/freshen up to smooth them out?
Thanks,
Matt
1986Browns
Re: Rear view mirror replacement/window question
Post by 1986Browns »
There should be a metal clip that is glued on to the windshield glass itself. The rear view mirror assembly slides down on to that mounting clip. The mirror should just slide off of that metal clip, it may need a little extra nudge though if it has been there 20+ years.
This. I replaced the mirror on my '89 GT awhile back and it came out of the windshield clip without too much trouble.
Doughrat19
Mirror is all set. Just took a little extra work seeing the clip came off with the mirror. Had to glue it back before I could hang the mirror.
Anyone know anything about the Windows? I just rolled them up and down and my description would be they are choppy and both sides squeak a little at one point during the process just for a second.
Doughrat19 wrote:Mirror is all set. Just took a little extra work seeing the clip came off with the mirror. Had to glue it back before I could hang the mirror.
You can take the door panels off and try to adjust the keepers, or look at them and clean them out if there is some trash or build up in them. Might not hurt to lube the parts while the door panel is off also.
Doughrat19
New mirror looks much better!
ImageOld and new rear view mirror by Doughrat19
