I grabbed my fire extinguisher that was only 10' away and got low to have a look. Apparently hot exhaust and decades old oil/grease leaks are a bad combo. I had a full blown fire near the cats! I pulled the pin and gave it a couple good sprays. Fortunately the freak'n fire went out.
After I had a moment to access the situation, I realized this could have been a REALLY bad day! The car was buried behind others in the garage and all of the other keys were back at the house. If I didn't have that BEAUTIFUL fire extinguisher readily available, it could have been catastrophic! If I had more time and more wits about me, I would have sprayed from the other side (away from the 00R). The R got a dusting and the floor was a mess. This gave me a reason to pull the cars out for a trip around the block to blow the dust off and to give the floor a good cleaning. I finished with a California duster for the cars and put them back for some more slumber. The 89 will not be run again until it's time to restore it!
If you don't have a fire extinguisher in your garage, go get one! (I need a new one!)
