NIB Ford Racing ECU Main Harness part #M-12071-C302 (exact replacement for a 92/93 harness)
NIB Ford Racing Injector Harness part #M-12071-L302
NIB Motorcraft IAC valve with gasket part #E9AZ-9F715-BA (CX-1824)
Ford Racing Relay Pack Part # M12071-K302 (oxygen sensors were used for 10,000 miles)(rest is NIB)
Low mile Motorcraft 93 throttle body (F3TE-JC)(very nice with gasket)(throttle cable bracket w/ hardware)(IAC and TPS are attached)(used for 10,000 miles)
low mile Motorcraft water temp sender, air charge temp sensor ACT and heater bypass temp sender (used for 10,000 miles)
low mile Motorcraft MAP sensor (used for 10,000 miles)
Reman A3M1 5.0/5-speed air bag computer (been in a garage box for over 10 years)
I would like to get $1200 for everything (plus any boxing and shipping charges if you are not picking the parts up)
The harnesses and a lot of these parts have been obsolete for years as you know. I have posted many pictures below for all to see.
