FOR SALE- COMPLETE ENGINE 1993 FORD SVT COBRA
marshaly73
Post by marshaly73 »
47,000 Original Miles
STOCK FACTORY MOTOR, Never opened up or modified, perfect running condition, regular oil changes and maintenance performed. Motor is only for sale due to recent replacement with a high performance build. The stock set-up will take up space and needs to go. Motor is being removed Sept 2008, it will be sealed up, and will be put on a cradle and crated for shipment by builder.
FEATURES:
-Stock Late Model Year Cobra Intake Assembly, integrated EGR (this is the second version released from the factory, it is higher flowing then the earlier model)
-Stock 65mm Ford Racing Throttle body
-Stock Cast Iron GT40 Cylinder Heads
-Stock 1.72 ratio Crane Alum Rockers
-Stock 47,000 mile assembled Shortblock(pistons, rods, crank, rings, bearings, lifters, dog bones and spyder, including timing cover, water pump, oil pump, pick-up,oil pump shaft, dipstick, timing chain, harmonic balancer, 50oz, etc…
-Stock Cobra Cam
-Stock Low Profile Black Valve Covers
-Stock Black Oil Pan
-Stock Fuel Rails and Fuel Pressure Regulator
-Stock Headers
-Stock Rubber Inlet Elbow and MAF Bracket
-Stock 93 Cobra Computer, 24lb inj and 70mm MAF available also, the meter must be used with a 24lb inj and the Cobra computer, will not work with A9L or A9M.
MOTOR DOESN’T INCLUDE, water pump bolts or studs, distributor including rubber cover, cap/rotor, accessories, front accessory brackets and pullies, sensors (tps, EGR, Air Temp, Water Temp, IAC, etc)
FOR SALE- WC T5Z TRANSMISSON SET-UP FROM 1993 SVT COBRA
-World Class T5, Z spec Cobra, shifter included, shifts smooth, excellent shape
-3.35 first gear
-Stock Bell Housing and clutch assembly also available
$3,000 OBO Complete Motor
$800 OBO Tranny
Dantak
Post by Dantak »
how much for the tranny without everything else...i just want the tranny.
#4524 Teal/Leather/Sunroof/Power Seat
Chrome Intake/Upper Radiator Hose
Strut Tower Brace
Long Tube Headers
Mac Exhaust
Subframe Connectors
4.11 Rearend
Aluminum Driveshaft
K&N Air Filter
Pro 5.0 Shifter
King Cobra Clutch
Fidanza Flywheel
Ackman70
Post by Ackman70 »
It's in his ad.....$800 OBO.
Former owner '93 Cobra #375 Red/Grey leather
Dantak
Re: FOR SALE- COMPLETE ENGINE 1993 FORD SVT COBRA
Post by Dantak »
marshaly73 wrote: FOR SALE- WC T5Z TRANSMISSON SET-UP FROM 1993 SVT COBRA
-3.35 first gear
$800 OBO Tranny
This is what's in the ad. I don't want the shifter, the bell housing or the clutch. As I said, how much for just the tranny?
Strut Tower Brace
Long Tube Headers
Mac Exhaust
Subframe Connectors
4.11 Rearend
Aluminum Driveshaft
K&N Air Filter
Pro 5.0 Shifter
King Cobra Clutch
Fidanza Flywheel
rw93cobra
Post by rw93cobra »
pm sent
1993 Mustang Cobra Teal with gray leather int. #4547
1993 Mustang Lx with supercharged 347...soon to be t76 turbo'd 331 with cobra body kit
2003 SB Cobra
1994 White Ford Lightning
