Anyone have the brand and part number for our 93
cobra's as far as replacements?
Thanks
Ben
Fuel Injectors
Re: Fuel Injectors
I don't have a part number or know if they are bosch or what, but if you have one stuck i would pull them all and send them off to be cleaned and flow tested. It cost me about 350.00 to all mine. Your original injector can be saved and you can make sure you won't run into the problem again.
Re: Fuel Injectors
I had thought about doing that, but what if it is an electrical problem, would still have to get one, correct?
Re: Fuel Injectors
I have never seen a injector have a electrical problem, they will check the injector and they flow check it the electrical part of the injector will have to work for it to flow. If they check them and they are fine, i would get something is wrong with the harness. I willing to bet the injector is fine and harness, injector just needs a new plunger or something simple.
Re: Fuel Injectors
if your looking for a potential source, I've used these guys (note, I have zero affiliation). Their URL sort of explains what they do....
https://www.injector.com/cart/pc/viewCa ... ategory=30
Re: Fuel Injectors
Ok, thanks for the info. I will try this.
Re: Fuel Injectors
we flow all our own and have been for the last 20 years... if people are paying $350 for 20 minutes worth of work........sign me up. I'll do 8 nozzles for half.
93r #17
93r #54
95r #007
66 shelby 6s623
93r #54
95r #007
66 shelby 6s623
